Zmodeler selection
Hi I’v been trying to figure out what zmodeler selection distance does. It is under interface in the preferences folder. I’m hoping it will make selecting edgeloops or points easier but I don’t see a difference.
Any advice would be appreciated.
I’ve never touched it, so I can’t explain further than what the ctrl-mousover pop-up tip says. It’s never been important.
However, to make element selection easier with Zmodeler, simply adjust the brush radius up or down, depending on the situation. Large brush sizes can cause unintended behavior. Small brush size makes it easier to hit your intended target.
Likewise if you only want to affect a certain target type in a crowded area (point, edge, or poly), set the other two action modes to “do nothing”.
