hi
in new zbrush when I add multiple edges it destroys topology. makes the triangle.merges them…
so please fix that. it’s not like before.
Hello @naghi,
There could be 2 different things in play here.
The value in Preferences> Geometry> ZModeler Welding Tolerance. Reduce this to a minimum value. You would then have to store the config (Preferences> config> Store Config) for the changes to persist at startup.
The Tool> Geometry> Size >XYZ Size of your mesh. The ideal size for working in ZBrush is approximately 2. Meshes drastically larger or smaller than that value will experience odd behavior. In this case, if your mesh is especially small, you may experience unintended point welding even at a minimum value.
Good luck!
thank you,will check that
it worked well
