Hi all,
I was trying to use the ZModeler to close a hole using a Convex shape, I usually do that to create a “semi-spherical” cap, but I discovered that the interactive curvature (and even the fixed curvature) doesn’t work anymore. I’m only allowed to close the hole with a flat surface, meanwhile there is no problem when using Insert Multiple Edge loop with Interactive Elevation.
This is the first time I tried that feature in the new release 4R8 (P2), has anyone faced the same issue?
:o help :o
