Hi every one!
I’ve imported a OBJ file from Max already Unwrapped into Zbrush and I started my modelling until Subdiv Level 7 but then when I went to ZMapper to generate the normal Map I get the following Message:
Plugin Note: Memory could not be allocated, and then it says: SubdividLinksQuick
and it doesn’t let me generate my Normal Map…
Any idea of what can be causing this problem and How can I solve it?
Thanks;)
