ZM polygon tools
Hi everyone this is new tool
ZM polygon tools plugin for Zbrush.
The ZM Polygon tool is developed based on the ZModeler brush, integrating a command property routine.
The reason for creating the ZM Polygon tool is that the default ZModeler interface has an overwhelming number of buttons and properties, so I have optimized certain aspects to make it easier for users to manipulate.
The Vertex, Edge, and Face properties are separated. Each property, once set, triggers over 100 commands and is saved in the ZModeler brush format.
When working with Vertex properties, the Edge and Face commands do nothing. Similarly, when working with Edge or Face properties.
Support Zbrush 2022 ,2023
1a
Tutorial ZM Polygon tool plugin for Zbrush Tutorial - YouTube
I hope you like it.
Great Plugin idea !!! Thanks @tonhai25
