Hello!
I have an issue using the “GetFileNumber” command from ZFileUtils.dll that I downloaded from ZBrush Docs
When I use the command on a folder that contains a very large number of files, it just doesn’t return the right number.
I made a test script that will print the number of files in a specific “import” folder and as you can see in the attached screenshot, the script prints out the number 346 even though the folder actually contains 384 files.
If you wan to check it out for yourself, feel free to download my test script and place it in your ZBRUSH_ZStartup/ZPlugs64 folder.
Test.zip (1.2 MB)
I was wondering if someone has an idea on how to fix this or know of a workaround?
Thank you very much!
Gabriel
