](javascript:zb_insimg(‘13467’,‘ZcurveInfo.JPG’,1,0))
When you are satisfied with your Curve you can transform it into a 3D Mesh consisting of Zspheres. Note: Since the mesh is also encoded with position and size information it is compatible for use with my Zif Worm program.
:ex: Update 6/23/05 Version 1.1 :ex:
Added 3 Point Curve selectable in the Settings Menu
Using the 4 Point Curve is a typical Bezier function
Using the 3 Point Curve can create more elliptical or oval curves.
:ex: Update 7/1/05 Version 2.0 :ex:
- Zcurve will now “Remember” all settings so that you can load another script and then return to Zcurve. It will not remember Zsphere data so be sure to press the “Apply” button to gather data before using the “Create” button.
- Placed “Grid” spacing and “Rotation” angle in Settings Menu
- Added XYZ sliders to use as display and Input when using the Navigation panel on a selected object.
I had wondered whether such a thing was possible and thought you’d be the one to do it. I can’t wait to try it out. Thanks!
i will try this one when i have some more time, thanks for the script
