Zbrush's window keeps freezing so i can't move it! help please
My ZBrush’s window keeps freezing so i can’t move it! . I need to move it on my computer screen so i can see other windows from other applications but it won’t let me move it at all. This has happened to me a lot in the past but i was able to temporary solve it by restarting ZBrush or my computer . Lately doing that is not helping
I appreciate your help
Thanks
It may be a memory issue… just a guess. However I use dual monitors when working on projects. Check to see if your system has an additional monitor outlet. Most laptops do but I am not sure about desktops. If you do have an additional monitor outlet check in to inexpensive but nice monitors at your favorite electronics vendor (like BestBuy). You don’t have get a huge 20+ incher to get visual assistance you are looking for unless you want it.
Once your plugged in and hooked up, you will likely need to adjust monitor settings. Right click on your desktop, click Screen Resolution, and select “Extend these displays” on the “Multiple displays” list. Depending upon which side your monitor is on you may need to designate which one is your main by clicking and dragging the one or two monitor to the left/right side. Once configured click ok.
hi
i only have and use one monitor my laptop’s origional monitor
thanks
