zbrush4.0 transparent glass glass / transparency help: how to make a realistic glass
Hey guys! I am just start using Zbrush.
I want to create 8-angle crystal / glass necklace (Figure 1)
I first used maya modeling, then imported to zbrush4.0 (Figure 2);
Then, For material I choose GelshaderA, render settings I opened transparent, also opened the third icon in the subtool (the two circles overlap), render select best, the result is like this! (Figure 3).
I really did everystep what this post said.
http://www.zbrushcentral.com/showthread.php?t=95629
How can I use zbrush4.0 to create real glass transparency as in Figure 1?
You can only get glass if you use BPR. Were you rendering in BPR? Also, you won’t see the glass effect because you don’t have anything behind the hex piece to show that it is transparent.
