Zbrush Zooming in not working
I just moved to mac recently but had been using zbrush for a while.
I am very used to the “+” “-” shortcut for zooming in and out, however I only been able to zoom out with “-” but nothing happens with “+”
On a side note i had similar problem with brush size control “[” “]” only been able to make the brush smaller and not the other way. But I did found the solution for that but not with zooming in.
Current setup is iMac 27 2019 running Catalina
Hi @Ren_Chang_Lee
Did you assign the “+” and “-” keys to the “In” and “Out” buttons in the Document palette? That should work.
Thank you so much!
Did not know that the buttons is under Document palette.
For some reason either Zbrush or Mac is not registering the “=/+” key as “+” automatically so I had to change the “+” shortcut to “=”
