Zbrush Zapplink Issues (4r7)
Hello all!
I am getting an error in Photoshop when exporting layers from Zbrush via Zapplink. The Photoshop error is this “could not complete your request because the file is not compatable with this version of Photoshop”
Im using a multi-layered workflow for a tiling ground texture in Zbrush 4r7. There are 6 layers all with different matcaps applied.
This error only shows when exporting more than one layer. This used to work in 4r6 but now the first time I try this in 4r7 it give me that error. Based on other research done it seems that this error means that the file is getting corrupt somewhere but im not sure if that is the exact problem.
Im currently using a 2048x2048 document resolution and have tried both exporting at resolution and at AA half resolution. Exporting with multiple matcaps applied or just one matcap applied doesnt change anything. The target app setting points to the Photoshop .EXE and 4r7 is the only version installed on my computer. I also tried a reinstall and no luck.
Zbrush 4r7 (32-bit)
Photoshop CS6 (64-bit)
Help with this would be greatly appreciated, Thanks
Can you use ZBrush 4R7 64bit instead? I can confirm a problem with 32bit ZBrush but it’s OK with 64bit.
Wow, cant believe I didnt think of that. Frustration does indeed cloud the mind. It works without a problem on the 64bit version. Thanks Marcus!
