ZBrush won't render to Keyshot on Mac OS X
I have bought a license for the bridge plugin to render files in KeyShot. I have installed the licens (via Firefox it did not load with a file extension, in Safari that part went right and it installed correctly…)
However when I want to render via external render and press the PBR button, after a short while it says: “unable to connect to external renderer”
How can I fix this?
I’m having the same issue. Full version Keyshot Pro 5.1, Mac OS. Installed license, activated license. Set BPR to external render. Keyshot starts up, but then Zbrush tells me “unable to connect to external renderer”.
thanks for any help
I have that same problem too (on an i7 iMac). My solution was simply to open Keyshot before I clicked BPR, and then seems to work ok when I press BPR. It would have been nice to launch Keyshot from within ZB though…
