Hi. When I start Zbrush it’s larger than the ZClassroom UI. Things are off the screen on the right. Active Poi is where it cuts off lengthwise on top, Poly F is where it’s cut off height wise at bottom right. I’ve tried using the NVidia resolution settings but that just changes my startup GUI for Windows 7 Professional. I’m using a 36" Vizio TV as my monitor and had no such problems with ZBrush 3.5. Can anybody here help my out? Thanx for listening. I don’t know how to upload an image of the Zbrush screen.
Delete the contents of your ZBrush 4.0\ZStartup\ConfigFiles folder. That should resolve the issue.
Thanx Aurick, I’ll give it a shot. Ken
Aurick, did what you said but same screen came up with a lot of boxes about missing config files. Anything else I could try. Thanx
That’s very odd. I just tested it myself and things worked perfectly. The config file was rebuilt by ZBrush.
My recommendation at this point would be a full reinstall of ZBrush. Uninstall it, delete its folder and then reinstall and reactivate.
