Everything is installed correctly yet it doesn’t seem to work. In the trouble shooting guide one of the options is to associate the .JSX file with photoshop, I have no such file listed on my machine.
Are you using Photoshop CC? I don’t think it works with earlier versions.
Yes, from 2015.
When you press the Send To PhotoShop button the plugin will create a JSX file in the ZBrush 2018\ZStartup\ZPlugs64<b>ZBrushToPhotoshopData_2018\Passes folder. Right+click on this file in Windows Explorer then choose Open With and Choose Default Program. Make sure you select PhotoShop CC and then try the plugin again.
Thank you Marcus that worked.
I had the same sort of problem but when I clicked send to photoshop ZBrush would try to send to Adobe Audition instead… the solution given above fixed this also.
HI - It did not for me (6 years later), Nothing works! I right click my ZBrush 2025\ZStartup\ZPlugs64ZBrushToPhotoshopData\Passes and it takes me to 2025 Photoshop with a little title, ZBRush to PhotoshopCC. But will it sesnd me my .jsx file? NO! My Beastie Photoshop keeps saying it does not recognize the file ZBrush send it. I assigned the .jsx in Windows Default, yet that did nothing. Some how I am failing to get the right combo, Nothing is quarantined by Windows Defender; uninstalled all the old Maxon, ZBrush and Photoshop; restart, reinstall Maxon, ZBrush via Maxon, and finally the new ZBrush. It HAS to be something simple as NO where can I find any other solutions.
