Hi there,
well…I am not sure how to explain the issue but I will try.
if I was working on one object in ZB and exported the displacement for it it will appear with a look that is workable but might need some adjustments, so I will go back and fix some miner areas, the next export to displacement might totally change in depth in comparison with the original one!!! Why? and how to fix that issue?
I was not so sure on the quality I am getting from this procedure and In all the plugins PDFs for the Displacement exporter for ZB the document talks about ready sets for Max Maya XsI but no Lightwave, but they advise you to go onto Zbrush central and ask users for ready made scripts…So I was hoping to get some scripts from users or even support from Pixologic for there product to be used into the other platforms like Lightwave…
so again I am just hoping to get better info or support that will include the Lightwave community into the other communities that would like to use Zbrush, I would like to be able to include ZB in everything I do…
thanks again for the support.
khalid
