I had not the slightest idea where to post this, but had an idea it might benefit someone.
To be frank, assume this is listed somewhere else, also must confess that of late have not
been as current with updates on Zbrush.
In any case.
One of the features I like to use is the zbrush to keyshot link.
I use the full version, but assume this is correct for the Zbrush version.
As you are aware you create a object in Zbrush, hit external render, Keyshot.
Object appears in Keyshot.
In the material editor of keyshot (if you look) there is a default map.
If you had created a texture map, it would be listed here also, but there
is a default.
You render, look and close down.
What I did not notice until late last night was that all these maps are stored in a
folder and never deleted.
Even after programs are closed the maps are still there and they are
big.( default .exr format)
If you did not know any of this I have an enormous surprise for you and your computer.
In Windows go to:
C/users/Public/Public Documents/ZbrushData/ExternalRenderer
If you are like me the list will amaze and sicken you.
My count upon being deleted was over 10gb"s
Hope this is of some use to someone.
