I use spotlight with some images and need add new image to my workflow but not to destroy position of previous photos. How I can do it?
Hi @1111176 ,
If you have your Spotlight images positioned as desired, simply import the image through the Texture palette, select it, and use the “Add to Spotlight” button. This will add it to the active spotlight and it can be positioned/scaled as desired.
Remember the image with the orange outline is the active image in the spotlight. Only it will respond to Spotlight wheel adjustments. When you add an image, it becomes the active selection so you can immediately adjust it. If no image is highlighted, the Spotlight wheel will affect all images.
