Zbrush reversing the order of the pallets in my trays when I store cofig or save UI
I am setting up the order of the menu items I am placing in my right and left tray.
I am finding that sometimes when I set the order of how I list the menu items in my right and left tray and then store config or save as a custom UI, when I start Zbrush or load the saved UI ,Zbrush has reversed the order of the items in my trays.
Anyone have a clue as to whats happening here?
THanks
No clue… :slight_smile: But yeah, it happens all the time, and sometimes even buttons disappear…
Thanks Regnas, Its always good to hear that its actually a Zbrush Peculiarity and your not just me!
So have you found any way to save the tray order they way you want it, or does it just load up scrambled at times, no matter what?
Thanks
Not the way I “wanted” it :slight_smile: but I found that if you try several different order, eventually one of them will stick…
You need a bit of luck on this one…
This has been an issue for a long time AFAIK.
When I set mine up, it was always exactly reversed, never any randomness - so I just added palettes in reverse order and saved config.
Yes, hsurBZ is like that, I’m afraid. :wink:
Did not get fixed in 4R8 :cry:
