Zbrush renaming subtool when exporting to Poser using GoZ
I was trying out the plugin Zwrap to modify Poser figures imported into ZBrush using GoZ. When I try to export the morphed subtool back to Poser using GoZ, I noticed that ZBrush would rename the tool and Poser would ask if I wanted to import it as a prop instead of as a morph. I tried renaming the subtool back to its former name, but again Zbrush would rename it again when exporting via GoZ back to Poser. Any solution to stop this from happening?
Hello @jettamesis ,
Neither ZWrap nor GoZ for Poser is developed or supported by Maxon or the ZBrush development studio. Unless this is an issue that doesn’t involve the third party plugins at all you will need to contact the developers for any problems.
File export names can be specified at the time of export in the export dialog, or in the export options for Multi Map Exporter.
Thank you!
