I do alot of uving in Maya, then I import the obj back into Zbrush. Sometimes its fine but sometimes it will mess up the UV order. There are even times where I have fixed it and something I do in Zbrush will break them again. I noticed that when I hid part of the mesh it would mess up the uvs. Has anybody else had this problem? Never really noticed it with R5.
I noticed again after hiding part of the model it ruined the UVs. I un-done it and then tried hiding part of the model again and they were fine. Very strange. The only other way around this is to just import the model from Maya as a fresh tool (Uvs are fine) and project the details back on. But the problem is I loose all my layers. No one encountered this issue??
Dam! No one come across this? No help??
Are you using ZB4R6 P2?
Hi Doug. It is ZB4 R6 though what is P2?
Patch 2 would be my guess should say in the title at the top. Go to ZPlugins AutoUpdate.
great! thanks Doug
