Zbrush Poyframe unexplicable behaviour
Hi everyone,
I have some months of ZBrush experience and I am having a problem with the Polyframe I can not explain. Or maybe it is not related to the Polyframe, I really don’t know because I can not find any problem similar in the net.
When I display the Polyframe, instead of having the clean poly faces, I obtain this color horizontal lines.
The Polyframe problem only “disappears” when I put the subtool out of the boolean mode or when I turn off the “Live Booleans” button.
I’ve also tried to delete the (apparently) problematic subtools I wanted to be booleans and create a boolean with an easy mesh, and even tried to use the boolean as a mesh and vice-versa but nothing worked out.
Only when I delete all the subtools but one or when I isolate the mesh or when I disable all the booleans options (as I said above), the Polyframe shows as it used to.
I have also tried to make a boolean with simple meshes but it seems the problem is not related to any of these things because the Polyframe keeps behaviouring this way.
Also, this is happening with new projects and tools…
Here it’s the polyframe as it used to look like (or the way it shows when all the boolean options are disabled
or the mesh is isolated) and how it’s showing right now when a boolean is affecting it.
I hope somebody can help me, I’m desperate.
Thank you in advance.
That’s how polyframes display when you have Live Boolean on and a subtool set to intersection or subtraction. It’s so you can see the subtool if you need to move it.
Oh! I see. I thought it’d affect only to the Boolean’s polyframe and not to all the rest. Thank you Marcus!
