hi guys i would really appreciate some help here. I have two normal maps here and one works correctly and the does not. When i use the map produced in mudbox it sits correctly in modo but the one from zbrush doesn’t do it. I can see there is a difference. What I would like to know what do I need to do in zbrush multi map exporter to get the zbrush map working as I don’t want to use mudbox.
Thank you in advance
LDG
edit - flip green so fixed.
