Zbrush movies noob question :)
Hi there!
Im working on my sculpt, and i want to record a movie. Planning to do it with the F History. Its working well, but i have the following question, please:
If i close the proyect and i lose the edit history… and then i open again the proyect and i continue the work… then i would not be able to get the full movie…
What am i missing?
Thank you!
You need to save undo history in your project from the sounds of it.
Ok thank you. It was not working for me (it was not saving the undos, and i had the option to do it).
I finally found the issue. not only you need to use the option unde “preferences-undo history-enable saving”.
You also must check the “undohistory” button on the “files” menu, or it will not work.
Thank you for your time :slight_smile:
