Hi, just had a quick question regarding subtool groups and merging. Is there a way to setup Zbrush to name subtool groups when you merge them? Right now I have in the attached example a folder named ‘bakeset1’ and when merged, is renamed as a single subtool to ‘Merged_bakeset01’ Ideally when merging folders it would be great to have the same name as the folder (then I can use a batch file name utility to just add ‘_high’ to everything later.)
Is it possible to remove the prefix merged and just have the same subtool name as the folder? Thanks
EDIT: Also had another question, is there a way to ‘polypaint from polygroups’ for all subtools in one go, or to macro that?
