Zbrush MDD and Marvelous Designer
Hello,
Is it possible to import an MDD file from Zbrush Timeline into Marvelous Designer?
I have bee trying to do this, however; when I record the MDD from Timeline, export the .obj file of the zbrush model, and import everything into Marvelous Designer, the model disappears when I try to play the animation.
It appears to be a scaling or vertices issue from within Marvelous Designer, but I am not sure what the problem is. The .obj model and the MDD file plays back fine from within Blender.
Any help would be appreciated.
Thank you,
Anti
I found a work around. If you import the .obj model and the MDD file into Blender and then export the MDD back out from Blender, it does work in Marvelous Designer. However, the orientation of the MDD file is strange. It requires some experimentation to get the model and animation to orient correctly.
