Zbrush Masking Problems
Well I am making a character for a game, and suddenly some problems with masking have began…
first I have masked the entire body and let the fingers unmasked to deform it to inflate them to make them look stronger…
After done, I erased the masked and tryied to do another mask to make an extraction to make an armor plate in the legs…
but when I try to rotate, scale, move or even ctrl+z the mask, this mask comes back to haunt me…
notice that it is the same mask I used to inflate the fingers earlier…
I’ve tryed everything, restart zbrush, restart the computer, restore the entire zbrush settings to the original , delete undo history, but nothing solved, I just can’t do a masking anymore with this problem… Does someone knows what could have happened and can help me to solve it?
NOTE: my version of zbrush is 4R6…
NOTE: Most up to date version is ZB4R6 P2
Enable Solo and see if your ‘problem’ still shows.
Do you have any layers for that subtool?
If so, then you may have recoded the mask too, as that’s one of it’s functions. Baking or deleting the layer will enable you to continue.
That’s the only thing I can think of that might cause your mask to re-appear.
