zbrush masking and selection
i create circle mask and now i want to fill that circle so i press ctrl and LMB dragging. so is there any tool that can fill masking inside circle mask or curve mask.
also how can i select edge loop in zbrush.
You can use the circle mask brush. To activate it just press Ctrl and click on the brush Icon. A window will pop up all the masking tools. Just select which one you need and will be selected until you change for other method. COnsider this draging masks also masks backface so probably after using you should clear the backface masks (Ctrl+Alt for delete masking mode)
You can also find usefull the Square and Center Buttons in the Stroke Icon. Same as with the Brush Icon this pops up a window with multiple curves and stroke modes. Just click on Square and Center to drag a perfect circle from the center.
thanks bro and yeah these tools are very useful too.
Don’t know about selecting edge-loops but you can isolate edge-rings(or poly loops, same difference) by doing this :
  • grab the lasso select tool (ctrl+shift and change your stroke to lasso, or from the brush pallet)
  • place your crosshair directly on top of an edge
  • click
this should select the edge ring that the edge you clicked on was part of
thanks rareseu. i am gonna try this one
