Zbrush IRC( Its still not working)
does anyone know of
A) a client that works for os 9 that can connect to it
B) the server
C) the channel
D) the room?
i believe that two of these are
socery.net
and
#zbrush3
Hi there REYD
I am on a windows box now…but I used to connect to irc on my mac with a program called IRCLE.
Here is a link to it>>> IRCLE
If it doesn’t work you can make a search “mac irc client” on that site and you will probably find some program that will work for you.
About the server:
Now I am using cookie.sorcery.net but you better go to the following link SORCERY.NET and choose one server from their list.
and the channel(no need for a room name) is #zbrush3
I think that is all…if you still having problems to connect to it…just write…ok?
HUGS
X
*** #zbrush3 Sorry, cannot join channel. (Client hasn’t responded to version check, try typing /join #zbrush3 again in a moment) Channel is full
and the damn thing keeps killing my connectionYour IRC software has failed to respond properly to the client check.
Try turning off or uninstalling any software addons or scripts you may be running and try again.
If turning off scripts does not help, then try emptying your ignore list, and making sure all CTCP response types are enabled.
As a last option, you may try uninstalling and reinstalling your IRC software or try using a different software program to connect to SorceryNet.
For further help, see: http://www.sorcery.net/help
*** ERROR Closing Link: Reyd[myaddress] (Client check failed)
cookie.sorcery.net is closing the connection
Connection with cookie.sorcery.net closed
