ZBrush gemstones loose their edges in keyshot
Hi everybody, I have a problem when I use the ZBrush gemstones, as the one created by the ring plugin, or other gemstones brushes, they loose their edges in keyshot. As you can see in the picture. Thank you for your helpIMG_20180710_121757.jpg
Hello, I have found something but it is quite complicate. Export as obj in Rhino, transform in Nurbs polysurface, export in OBJ again and import back the mesh.
