Hello!
I’m having an odd problem with ZBrush 4R6: The first time I run it, it starts and runs fine. Then after I close it (or if it crashes), when I next try to run it, it gets as far as a white screen with the Windows 7 blue spinning circle cursor, and… Stays there, pretty much indefinitely. Then after forcing it to shut down, every attempt to run ZBrush has the same result. It never opens again, until after I reboot.
So basically, I get one chance to run ZBrush per Windows startup.
Earlier versions from 4R3 onward worked OK.
I submitted a service ticket, but got busy and took a while to get back to tech support with some info; having done so a couple days ago, I still haven’t heard back. So I’m not sure if my support ticket has been lost; but I’m meaning to check again soon.
One thing support asked for was if I had modified or customized ZBrush, and I had not. I’m trying to upload a screen capture of my desktop, but the upload software is saying the file format (a PNG from Photoshop) is invalid. I think the layout is pretty straightforward and standard, but there might be a few buttons I moved around in 4R5 that remain in their custom locations.
If there’s something to try that invoives resetting ZBrush back to its defaults, I’m fine with that.
Here are my specs:
Windows 7 64-bit
Intel Core i5 CPU [email protected] (4CPUs), ~2.7GHz
8192MB RAM
ZBrush 4R6 p2
Not sure if it’s worth mentioning, but I have a Wacom Cintiq 12", and extend my desktop onto it. It’s always seemed to work fine, but I also have a Wacom Bamboo, the pressure sensitivity of which is for some reason not being picked up in ZBrush (but it does work in Photoshop). I’ve reinstalled those Wacom drivers at least once, could they cause problems?
And I saw a notice somewhere that a lot of problems are caused by anti-virus software (though perhaps that’s only installation), so I turned off Avast before attempting to run ZBrush, just to be sure. Made no difference; ZBrush still crashed on startup – on the second try, that is.
Any help would be greatly appreciated!
Thanks,
Spencer
