This is just a feedback to ZBrush:
1.) I would like, that for the next release of ZBrush, it is possible to see the Windows taskbar.
It’s really tedious to scale the ZBrush window every time, so that I can see and use the Windows taskbar.
Often I am also on the internet and like to look at references, simply as inspirations. And if I’ve to use shortcuts every time, just to switch to my browser, that’s cumbersome.
Sometimes I also use other Programs like Photoshop. Or I want to open another program on the taskbar while I am working in ZBrush.
2.) If you do not improve the UI, it would be at least reasonable if the own UI and their buttons and sliders stay there where you have set them as your own UI. It happens often, again and again, that some buttons or sliders shift slightly when I open ZBrush again.Probably because sometimes I work on another, connected screen and sometimes on another.
The own UI does not stand exactly to the hair, like i’ve made/set it. Often they move a little bit away from their positions (minimal).
