Zbrush can't use brushes
I keep running into this thing in zbrush where every time i try to use a brush all it does is rotate the model. Also when i try to use the paint mask brush it just does a drag select instead. Anyone know what’s going on? I’m in edit mode and already made the model editable. I was editing it before actually.
Hi Malphrush, welcome to the forum.
This will happen if your “Z Intensity” slider is not set to 100 when you draw the Tool on the canvas. If it happens again, just turn off “Edit”, set the slider to 100 then turn “Edit” back on. You will be good to go after that.
