I recently added on more brushes into my presets folder like always, and not all of them displaying now (using hot key ‘b’). It appears Ive reached some form of limit.
I emailed pixologic and their response was:
"You should not have added any files into any of ZBrush’s default installed folders at all. That is exactly why we created the Lightbox. By adding all of those in, it causes ZBrush to have to load them into system memory each time as it is starting up. This has the effect of also causing some key features of ZBrush to not be able to fully load into system memory and will lead to not only software instability but also corrupt saves and corrupt model files. You will want to revert everything you have added in before you encounter corruptions that will result in a loss of work. Any and all extra downloaded files need to be kept in a directly outside of ZBrush which you then map to using the Lightbox feature.
The ZStartup folder does allow you to put extra files into it, but that was set up ONLY as a quick convenience and temporary repository for an artist to place a few tools to load up that they are using for a particular project at the time. It should never have more than 25 items added into it at any given time."
Okay thats terrific and all but Ive never had any issue even with a ton of brushes in there, and I use zbrush daily. So is there a work around/setting I can change to increase the amount of brushes that will display? Because using lightbox is incredibly slow, by comparison.
