i am trying to work on a flat object but the brush does not seem to be affecting the flat areas, any idea why this is happening?
What brush are you using and at what Z Intensity?
was using the noise brush and some others, seems like it works only when i tilt the model and only sometimes, like it misses the surface also i tried many intensities, seems like it has no effect
That looks like those areas are just simply less dense. Can you show the polyframe?
actually there are differences in the mesh and subdivisions but here it is before i subdivided it, it works on the blue areas and not on the red
here is a link to the model also for anyone who wants to have a look
https://drive.google.com/file/d/13gX-_lFf-5e1jZPZrFbPoxVd-gBj_hac/view?usp=sharing
Downloaded your mesh. Works as I would expect.
dam i feel like an idiot, idk how am i having so many issues with it
If i were you I’d reimport your mesh into a new Zbrush session. There might be something in your brush that’s effecting it.
ahh i see why, i was using other brushes like the noise brush and using a alpha map with a brush regular brush seems to work fine just i was trying to get a sand blasted wall effect like this
