First, I was using 4r8 p2 when I created my female character, she had 6 subtools in ZBrush and the highest I could go was 6 subdivisions for each, sometimes 7 depending on how many tris/polys were on level one of the base mesh. And what happened is ZBrush crashed on me while saving the document, however, the document was 1.18 gb in size!
Here’s a breakdown of what I could or could not do!
What I can do:
The document will open
I can select each subtool individually
View materials on each subtool
Render the whole document
Zbrush crashes when:
When I try to go up or down a subdivision level, ZBrush will crash
Using UV Master, Decimation master or really any plugin on any of the subtools
Viewing selected polygroups individually
Exporting to OBJ file
The specific error that comes up when ZBrush crashes is:
ZBrush Executable has stopped working: A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available:
And when I open ZBrush back open, I get:
Your previous session of ZBrush was abnormally terminated.
What’s weird is that it’s not on that just one document ZBrush crashes when I lower a subdivison level, it does the same thing to the previous copies of the document too!
