So when I re-dynameshed a cylinder at Resolution 16, it created way too many polygons than I wanted, this makes it harder for me to sculpt the basic shape. I always want to start out low poly, but with this new dynamesh in zbrush 4r8, I am unable to. I even made sure that I don’t have Subdivision Level on or Dynamic Subdiv turned on. Anyone run across this problem and how to fix it?
Please check screenshot:
Probably your model is very large. Dynamesh resolution depends on scale. If the size of your model is not critical, you could press Tool>Deformation>Unify and try Dynameshing again.
Thanks so much! It worked.
