ZBrush 4R7 ZSphere preview problem
Hello guys… I’m using the new version of ZBrush and making some tests following a zsphere tutorial. I’m having a hard time making it work. When I use a root zsphere plus a child zsphere the preview works OK, but when I add another child zsphere something really strange happen. I’m attaching an image show the problem, on the left are the zspheres without preview, on the right the problem after I’ve applied the preview with the ‘A’ hotkey… Can somebody helpme please?
I’m using the 4R7 64bit OSX version…
Thanks a lot guys,
Cleverson
If you want zpheres to align properly, make sure you have x-symmetry turned on when drawing off the root zsphere.
Also it’s a good idea to have perspective turned OFF, and snap to a view (rotate with shift key held) before drawing out the sphere.
