Hi, i have a problem with goz in zbrush 4r4 sp2
when i have a tool in the canvas and i click on goz button, it appear on the top “file saved” but don’t open photoshop cs 6 extendend…?!? It’s a common problem, there is a problem of incompatibility goz-photoshop cs6 or it’s my error??
(i have just inizialized the path of cs6…zbrush confirm that recognize the program…)
thank’s for any support
Does your ZBrush model have UV mapping and a texture applied before using GoZ? If not then you need to correct that. Alternatively, if you want to PolyPaint you will need to use ZAppLink rather than GoZ.
Basically, when it comes to Photoshop, ZAppLink is for PolyPaint and GoZ is for direct painting on the texture.
Thank’s a lot
