ZBrush 4R3 BPR Transparency not working [Solved]
Hi everyone,
Is anyone else having problems with BPR transparency in ZBrush 4R3 ? I just cant get it to work and I know i’m doing everything i am supposed to (activate transparency in bpr rendering options, and turn on the intersection icon in the subtool pallete)
Can anyone put up a simple ZBrush file with spheres and working transparency just so I can test it out ?
I think there’s only two things you need to do:1) Turn on “Transparency” in the Render Properties tab. (Looks like you did that)2) Activate “BPR Transparent Shading” under the tool’s Display Properties tab. (You didn’t mention doing that.)You don’t need to turn on the intersection icon any more for transparency.
Thank you so much! That did it! I feel silly for missing this.
