Dear Forum,
I have used Zbrush 3, 3.5, 4, & 4 R2 without problem.
When I installed the Z4 R3 update, I started to get the following message on startup:
"Memory Error
Sorry, this action could not be completed successfully due to insufficient ammount of system memory.
Note: insufficient memory is a reult of edting a 3D mesh with highre polygon count than this system is capable of handling."
I get this messsage before I have even selected a tool to load into memory or draw on to the screen. All I can do is keep going “OK” to the dialogue boxes that appear, then the application closes. This doesn’t allow me to get at the memory section of the preferences to increase the amount of system memory that the program uses.
My PC has 8 Gb of RAM, and 95 Gb of spare HD space. It is running Windows 7, 64 bit.
I have looked at the other posts in this forum, and tried changing folder option “always show icons, never thumbnails.” This didn’t resolve the problem.
I hope that you can help. Although Zbrush 4 will run on my PC, I really want to be using R3.
Hope that you can help me.
Tim
