Hi All,
I just made a extensive ZBrush 3.5 Tutorial Video for UV Unwrapping.
The video shows how to use the new UV MASTER Plugin Available for free download at the pixologic website.
http://www.learn3dsoftware.com/zbrush35uvunwrap.htm
Topics Covered:
-1 Click UV Unwrapping
-Symmetrical UV Editing
-Control Painting
-Ambient Occlusion UV Unwrapping
-Density UV Editing Preset Editor
-Work on Clone Feature
-Copy and Paste UV Buttons
-Check UV Seams and Clear Maps Feature
-How to Combine UV Masters different types of UV Unwrapping Features together for more control over your UV’s
-Polygroup UV Unwrapping
-Polypaint UV Unwrapping
-Masking UV Unwrapping
-ZSphere UV Unwrapping
-Examples of how to unwrap different types of characters from basic low poly meshes to more high poly more complicated characters.
-How to use an external 3D Application in combination with UV Master Plugin to create much cleaner UV Unwrapping in ZBrush.
-How to Delete a UV Map off your mesh.
-How to Edit a UV Map in Flatten Mode using ZBrush’s Move Brush
-How to Export a UV Map to another 3D program for UV Editing and how to re-import back again with the new changes to the UV.
-Create UV Maps in ZBrush easily to use in your tradiional 3D Animation Package. In most other 3D Packages UV Mapping is a very time consuming process. Speed up your productional pipeline with the techniques in this powerful training video.
Basically an A to Z course on all the new UV Unwrapping possiblities/techniques in ZBrush 3.5 using the new UV Master Plug-in.
*Running Time: 3 hrs 45 mins-Approx.
ADAM GIBSON:D
[email protected]
