Update Available ZBrush 2026.1.1
Desktop Fixes
- Fixed a stability issue with help menu on macOS
- Fixed a stability issue with IMM viewer position being changed as well as being docked vertically
- Fixed a stability issue with the knife brushes on windows
- Fixed an issue with copy paste of IMM meshes to work in all tabs
- Fixed issues with Retopo Brush welding and symmetry
- Fixed issue with Retop Brush snapping geometry to other side
- Fixed Retopo Brush temporary polygons only moving on one side when symmetry was enabled.
- Fixed crash when collapsing polygons with the Retopo Brush.
- Fixed Retopo Brush only creating 1 triangle when welding at centerline
- Fixed scenarios with Retopo Brush symmetry failing with non symmetrical models
- Fixed ALT extrude polygons being visible behind the mesh when using Retopo Brush
- Fixed an issue with the rendering of the vertex preview
- Fixed an issue with a missing folder of Ambient Occlusion
- Fixed an issue with FBX export and wrong paths on macOS
- Fixed a performance issue with the smooth brush
iPad Fixes
- Fixed an issue with GoZ Cinema 4D and sequential names of Objects
ZBrush 2026.1.0 has arrived
ZBrush 2026.1.0 includes several new additions to your ZBrush workflow, along with additional bug fixes. Read below to see what’s been included in ZBrush 2026.
New Features
- Retopo Brush - available on Desktop and iPad
- Smooth Retopo brush - available on Desktop and iPad
- New Projection option for all Smoothing brushes - available on Desktop and iPad
- New Retopology sub-palette - available on Desktop and iPad
- IMM Viewer Enhanced by allowing you to create tabs for IMM and Retopo brushes. - available on Desktop and iPad
- Folder Restructure, which will provide users to add custom elements to their user profile. - available on desktop only. Learn more about the restructure.
- Photogrammetry Scanning - available on iPad only.
- QuickSearch allowing to find any feature in ZBrush quickly. - available on iPad only
- Import Multiple brushes, alphas and textures at once with automatic storing. - available on iPad only.
- Image export up to 4K - new to iPad version.
- Resolution Gate for image rendering. - available on iPad only.
Additional Desktop 2026.1.0 Fixes
Additions
- Add LightCaps to Lightbox menu
- Add support for env var to define user folder location
- Add updated Python SDK documentation zip
Fixed
- Crash with Merge Down with certain type of topoology.
- Crash with RS material picking
- Brazialian language could use another font as other western languages
- ZRemesher Crash When Keep Groups and Freeze Groups were activated.
- Decimation Master executes regardless of cancel action when export all is used.
- MacOS: If you are not singed into the Maxon App ZBrush will crash upon startup.
- Having a username with special characters will lead to ZBrush not starting up.
- ZBrush crashes when updating size ratios with Scale Master
- Sending the ZRide pro project to ZBrush desktop causes a crash on mac
- ZModeler causing crashes on Windows platform.
- 2.5D Sphere brush and Eraser brush not working
- Crash on fbx import with the Import Mats as SubTools
- Lightcaps folder with no light caps - Go to folder crashes
- ZSphere Retopo Crash When Deleting Sphere
- ZModeler My Presets not saving on PC
- Ring Utility plugin error
- Nano Tile Textures errors
- ZStartup Utility error
- DynaMesh Utility error
- Crash when canceling Tool saving file picker dialog.
- Localization updates
- Scale Master Unit cube button would cause a crash
- ZBrush to Photoshop CC plugin was not working.
Additional ZBrush for iPad 2026.1.0 Fixes
Fixed
- The brush hover dot color seems to be off in certain cases
- Some images loaded into Noisemaker did not create a preview, specifically EXR files.
- Analysis colors were incorrect.
- USDZ/OBJ import fails on iPad
- Occasional crash when closing ZBrush.
- 2026.0.2 (1) Newly added buttons are not localized in 3D print hub
- Increase performance to sculpting
- Selecting a texture was not enabled to UI immediately in the Light palette
- After painting temporary poly and pressing shift or ctrl on the keyboard you would delete polygons.
- Image export is cropped off or has an offset
- Sending a file from the iPad to Cinema 4D caused an error
Get ready for ZBrush 2026!
ZBrush 2026 Desktop Additions
available patches
ZBrush desktop 2026.0.1 is now available.
- Fixed an issue with missing Lightbox back icon as well as a crash when loading NoiseMaker from Lightbox.
- Fixed an issue with ZModeler Creasing Edges with inset each polygon.
- Fixed an issue with 3D Print Hub Visible icon.
- Fixed an issue with 3MF export and visibility options.
- Fixed an issue with X, Y, Z sliders in Scale Master not updating correctly with cm and ft measurements
- General stability improvements on Startup, ZModeler and Scale Master.
ZBrush for iPad 2026.0.2 is now available.
The following have been fixed.
- Micropoly meshes were not available. The library will now be available.
- Star polymesh appears on the first send through GoZ to C4D.
- After GoZ sent from ZBrush to C4D, and then save the file will make the file unreadable.
- User Textures were not appearing when the file was a PNG.
- Tap to exit Gizmo mode option was not saving in the Gear Settings
- 3D Print Hub ASCII option wasn’t in all caps
- Irregular behavior with the percentage slider in Decimation Master
- CamView was loading the incorrect default.
- 3d Print Hub and Scale Master were missing button translations
- NanoMesh brush wasn’t able to be created.
- Crash in Quick Menu if the depth pallet is clicked in the Brush menu
- IMM Brush Not Being Created When Building from Scratch
ZBrush for iPad 2026.0.1
- ZModeler creasing edges on inset polygon wouldn’t work if the option “inset each poly” was selected.
- 3D Print Hub and Scale Master single choice buttons were staying active.
- Renewing users unable to activate their license.
Python Scripting
This first wave of Python is being introduced as a standard scripting language in ZBrush, enabling users to create plugins, automations, and tools, similar to other 3D applications. This first edition has converted the ZScripting commands into Python. Providing a new way to automation within pipelines and aims to make ZBrush more compatible with pipelines.
Learn more about the Python Integration HERE.
ZModeler Continues to Grow
- ZModeler interaction improvements
ZModeler enhanced visibility when hovering over vertices, edges, and faces, makes it easier to model with confidence and to click on the right component.
- ZModeler Creasing Options Added to the Following:
Now when you Insert a Single Edge Loop or Multiple Edgeloops, ZModeler can automatically apply creasing to the insert edge(s). We’ve also added this ability to the Inset Polygon Action.
Noisermaker 2.0
NoiseMaker is getting a cool update! You can now switch off any inserted Alpha image directly within the NoiseMaker window. Plus, there are awesome new transformation features to play around with.
The following transformations are now possible with an Alpha Image.
- Rotation of the image to get that perfect alignment.
- Scaling on both axes to add a bit of squeeze.
- Offset on both axes to move the image to its perfect placement.
NoiseMaker now comes with handy Undo/Redo options, making it easy to cycle through your changes until you find the perfect noise.
The Pro Projects Library Expands
Yariv Newman of Pitch Dev Studios, 3D motorcycle sculpt, created in ZBrush, Designed and Art Directed by the incredible Scott Robertson, blends cutting-edge design with masterful detailing. This futuristic concept bike showcases the ability to design hard surface in ZBrush, all brought to life through dynamic sculpting and visionary design.
This is a perfect project to see how artists today take advantage of ZBrush’s hard surface techniques, including leveraging the LIVE Boolean system.
Founder of Pitch Dev Studios David Levy’s Instagram
See more from Scott Robertson:
- Scott Robertson’s ArtStation
- Learn more about design from Scott at Design Studio Press
ZBrush for iPad Additions
Ready, Set, 3D Print
The ZBrush for iPad 2026 version is keeping up with its feature parity by including some of our favorite 3D printing features. We’ve added several essential tools to improve the 3D printing pipeline in this release. Check out the list of new features below.
- 3D Print Hub has been added, this plug-in allows you export models to a specific scale without changing their physical size within ZBrush’s document space for 3D printing and more. With this new addition, you’ll now have the following capabilities.
- STL Import/Export with or without color
- VRML export with or without color
- 3MF export
- Ability to export multiple Subtools as individual OBJs, STLs, 3MFs and VRMLs files.
- Scale Master has been added. With this feature, you can easily set a world scale and fine-tune the physical size of your 3D models within the ZBrush document space.
Create your own journey
We’ve added some exciting new features to help you create your own unique experience with ZBrush for iPad.
Modifier wheel size and rotation can now be adjusted with two fingers.
You can now move your custom toolbar from the bottom of the screen to the top with just a flick. It’s no longer limited to the bottom of your UI!
Your custom QuickMenu’s , while holding spacebar, can now be added to the tray to allow you to keep your favorite QuickMenu.
Import and Export custom UI which will store the following:
- Custom Toolbar settings and location
- QuickMenus
- Modifier wheel size and location.
- Tray location
- QuickMenus
- All User Settings
- ZModeler Presets
ZModeler growth continues
Keeping the ZBrush for iPad aligned with desktop, the iPad version also receives the ZModeler additions.
- ZModeler visual interaction improvements for easy identification of polygon, edge and vertex click targets.
ZModeler creasing options added to the following:
- Insert edge loop
- Insert multiple edge loop
- Inset polygon face
let’s make some noise
ZBrush’s acclaimed Surface Noise feature continues to expand. The ZBrush for iPad version has received another UI update, ensuring seamless interaction across all iPad sizes. Allowing the freedom to edit noises and still have the ability to edit the main controlling settings of the overall noise. Welcome to NoiseMaker 2.0!
- New UI allowing for greater workflow flexibility
- Alpha image now has transformation ability (rotate, scale, offset)
- Individual noise reset as well as global reset.
- Ability to undo/redo changes within in NoiseMaker.
pro projects library continues to expand
- Pro Projects are now cloud-based and can be downloaded and managed with ease. With every Pro Project, you’ll get a handy information card that covers everything you need to know, including file sizes and all the goodies you receive with each project.
- The new Scott Robertson and Yariv Newman Pro Project has also been added to the iPad version.
- With this new project, the FREE version of ZBrush for iPad now lets you easily toggle LIVEBoolean on and off. Plus, you can now select Subtool Boolean states too.
SEE ZBRUSH 2026 IN ACTION…BUT WAIT THERE’S MORE…SEE WHAT ELSE IS ON IT’S WAY SOON.
- New folder restructuring
- A whole new retopology brush
- A UV Editor and more.
Enjoy the new features!
Your ZBrush Team!
