Zbrush 2023 fails to create Displacement map
Hi. When I export maps via multimap, Displacement, Vector and Normal Maps are not created. Zbrush does its thing and there is the ’ all files successfully created’ message, but the folder stays empty. Other maps work but not these. The model is a hi-res scan so I assume it has something to do with the model integrity and I painfully cleaned the scan in MEshlabs. But still no luck. I am desparate.
Any ideas? Thank you.-
