ZBrush 2021 - Mesh disappears if decimated with Keep Polypaint on
Using Zbrush 2021.6.2.
When I decimate my meshes with Use and Keep Polypaint, the model just disappear, including other visible subtools. I can make parts of them reappear sometimes by Ctrl+Shift+Dragging across the canvas, but nothing I do succesfully shows the whole mesh, and moving the camera at all makes the mesh disappear again.
This does not happen if Use and Keep Polypaint isn’t marked on the processing phase, it works fine in that case, but of course Polypaint information is lost. Anyone can help?
Hello @Vi3D
Does pressing “F” not frame and reveal the mesh?
Otherwise, I can’t immediately recreate your issue. If you contact Pixologic Support with the email address your license is registered with, we can take a look at your installation and the tool being used in greater depth.
Thank you!
No, it does not. Also, I found it’s a specific ZTool I was using, sent by my employer for me to work on, I"m talking directly to them right now. Thank you for the answer nonetheless.
