Hello
The new 2021 release crashes almost any times when load custom interfaces . Mostly in scripts that use command load ui . I tested on MAC and WIN machines and the result is the same …
I have made plugin for zbrush called Zbuilder . THe script has different options and load different UI . Before 2021 all worked fine but now almost any time it crash when load two or three custom UI in the script line …
[IPress,Preferences:Config:Load Ui]
I hope this will work again in some update
Thanks
