Ever since the Brush 2021 update shortly after starting ZBrush with a Wacom tablet enabled (I can’t reproduce it without the Wacom) if I hit certain key combinations (namely the command + option + shift or control + option + shift) the command key acts like it’s being pressed down, and it doesn’t stop. I have to restart the entire machine because it affects applications outside of ZBrush.
I can only get this to trigger from within ZBrush, no other app triggers this and it only started happening right after ZBrush 2021 was installed. If I revert to my old ZBrush 2020 the problem now happens there too. I’m guessing maybe some kind of shared accessibility setting got changed for the shortcut keys (ZBrush also doesn’t ask for input monitoring I’ve noticed, most other apps using a Wacom do.)
My system specs are as follows:
Mac OS Catalina 10.15.6
MacBookPro16,1
Processor Name: 8-Core Intel Core i9
Processor Speed: 2.4 GHz
Memory: 64 GB
Wacom Intuos Pro PTH-660 (latest drivers)
