ZBrush 2021.5.1 is Available Now
2021.5 Featured
First previewed during the 2020 ZBrush Summit, this release for ZBrush 2021 includes features that enhance everything from Sculptris Pro to ZModeler. It even brings 3D Connexion support to ZBrush! The new features and enhancements in ZBrush 2021.5 will benefit every ZBrush sculptor… and it comes as yet another FREE upgrade for all registered ZBrush users. Read on to learn the exciting details concerning the features and enhancements available to you in ZBrush 2021.5.
What’s New
Thick Skin
For the true sense of adding, removing or moving clay across a surface use Thick Skin. This gives any mesh the appearance of having been sculpted as a fine art piece. Thick Skin can also be used to establish a specific plateau from which to build upon a surface to create scales and other features with consistent height or depth.
Sculptris Pro Enhancements
Sculptris Pro performance has been improved, further empowering it as a system for true creativity without limitations.
Contrast
Didn’t sculpt those wrinkles deeply enough? Need to enhance the details of those fish scales for a 3D print? The Contrast slider provides you with the ability to globally enhance all sculpting details while the Contrast brushes make it possible to focus on specific areas to heighten your sculptural details. Specific depths can be applied on an individual basis and even be adjusted in real-time, giving true freedom to experiment.
Contrast doesn’t just bump the details. It can also be applied to smooth a surface back towards the original state before any sculpting details were applied.
Curves Helper
Need to tie a knot around that character’s waist, create a flow of wires through a mech or apply laces to a shoe or boot? Curves Helper is your answer! It’s simple: draw any shape with ZSpheres and adjust it to fit your needs. Then with a simple click, convert the ZSpheres into an editable curve that will now allow any surface to be applied along the curve.
Continue your edits in Curve mode, including swapping out the geometry being applied along the curve.
Preview Ambient Occlusion
Sculpt with real-time render accuracy that captures every stroke applied to your mesh. Real-time ambient occlusion gives you the ability to quickly see which portions of your model might need that extra touch. Bring your creations to life in real-time with the Preview AO (Ambient Occlusion) feature.
ZModeler Additions
Don’t let the walls of your topology restrict your creative process. Slice your topology along an edge, face or point to control the direction in which you want to take the construction of polygons. Once you’ve got everything in place, apply a crease to multiple edges with two clicks to maintain that crisp edge needed for your next hard surface model.
Use the Fill PolyGroup option to mark the faces where you will add an extra layer of topology to create a suit of armor or the right touch of detail on a utility knife.
Axis Rotation
Lock your model to one rotational axis to give you that real world feeling of working on a sculpture stand, just like the clay masters did. Use the Axis Rotation option to specify a degree of rotation for your model during a presentation meeting or limit your viewing area of interest to just one portion of the model.
3Dconnexion Mouse Support
Navigate in a way that frees you from a keyboard. Using the line of 3Dconnexion mice gives you the ability to navigate with just a slight touch of the navigation knob. Rotate and zoom at the same time or pivot around the point of interest without breaking your sculpting stride.
And More…
  • Two new Render Presets have been added.
  • A new Radial Overlay filter lets you focus your render on a specific part of the scene.
  • Various plug-ins have been updated.
  • Four new demo projects have been added to be used as a base for many sculpts.
  • Several brushes have been added to take advantage of the Thick Skin feature.
2021.5.1 Update
This update focuses on fixes and tweaks to improve the overall ZBrush 2021.5 experience.
  • SubTool saving updated when using SculptHD mode
  • Resolved HD Geometry stability issue
  • Dynamic Subdivision with FiberMesh no longer causes visual artifacts
  • Material Transparency rendering issue resolved
  • Dynamic Subdiv causing artifacts when rotating has been updated
  • ZBrush To Photoshop CC updated to fix a layer issue
  • Scale Master updated to work with Dynamic Thickness and will now detect hidden geometry
  • Decimation Master updated
  • Axis Rotation updated
  • Maya BlendShapes updated
  • Maya .ma ascii file export fixed
  • Option Added: When adjusting the slider the Shift key can now round to a whole value
  • Poseable Symmetry returned to 2021.1.2 functionality and works with multiple subdivision levels
  • Inflate brush updated to take advantage of Thick Skin
  • DemoHead project restored
  • Default UI tweaked
Availability
ZBrush 2021.5.1 is a FREE UPGRADE for all registered ZBrush users. It is also available for new users to purchase immediately.
Purchasing
ZBrush 2021.5.1 may be purchased from our online store for immediate download.
It may also be purchased from any of our authorized resellers.
ZBrushCore users can move up to ZBrush 2021.5.1,
Upgrading
Please see our Knowledgebase Article for detailed instructions on how to upgrade, based upon your license type and current version number.
Issues?
If you have any issues with upgrading or with the new features, please post in ZBrush Help & Support or start a Support conversation. Please note that account and login issues can only be handled via a Support conversation. Thank you.
Happy ZBrushing!
The SpaceMouse support is great, I will probably buy one soon (3Dconnexion SpaceMouse Wireless for a bigger one lacks space xD)
Thick Skin is great like many other new features before it, I love Zbrush^^ I always take the time to watch the live streams (Summit and Announcements) (they are always informative and fun to watch).
Nevertheless a Zbrush is missing a UV tool like the “PeelUV” introduced on 09/29/2018. Even if the UV Tile(UDIM) function was not shown or not included, it would fit well to PeelUV.
With the PeelUV plugin with UV Tile(UDIM) function the UV creation in Zbrush would be raised to a whole new level and so the new features that have been released so far would be supported positively.
I and many others who love Zbrush and are waiting for the PeelUV plugin to make our work even faster and better.
That this plugin is still coming, even if some people have already declared it dead.
I think it’s more true to the motto Legends don’t die, so PeelUV is “Missing in Action” for me, so please Pixologic team brings PeelUV to Action​:blush:
Greeting to the team, nice Update Thanks.
I also agree the 3dconnexion support ROCKS… though does anyone else find that the modifier keys are not working?
i.e shift ctrl etc… on the 3d mouse for example.
Congrats Pixologic on ZBrush 2021.5 :clap:
Great stream @PaulGaboury @Piggyson & @Pavlovich !!!
Thank you
Thanks for having me, I always have a blast with you all! Can’t wait to see what the ZBrush central crowd does with all the new features!!!
Thanks!
Thanks a lot !
I really appreciate the 3dspacemouse support and the new sculptris pro mode with hidden geometry !
David
