Zbrush 2019 Decimation Master bugs with folders
i have several folders.
im wanting to pre process a single folder group.
i turn off visibility on all folders/subtools.
i enable visibility on my subtools in chosen folder
When clicking “preprocess all” it starts to process the visible subtools. when it gets to the hidden subtools in the other folders, a pop up “NOT visible” appears. you then have to manually hit space bar for a bunch of hidden subtools as the script goes though them.
after this this preprocessing begins.
hope this helps repo it.
cheers
Many thanks for letting us know - we will fix that. In the meantime you can stop the notes and pre-process more quickly by turning on the “Skip Notes” button in the ZScript palette.
