I know it’s not a plugin but i think the ZBrush ZScript Utilities Forum is not a bad place to post that thing.
Are you missing the look of ZBrush 2 ?
Here is it back !
Cheers
Roland
Here is it back !
Cheers
Roland
Cool idea … thanks!
Thanks,I liked it that way!
Steel gate valve is excellent for use anywhere a shutoff valve is needed. Steel gate valve can also be used where throttling capabilities are desired, although this is not generally recommended as erosion of the seat and disc occurs due to the vibrations of the disk in throttling applications…from the site www.ulovalve.net/gate-valve.htm
