zb4r7 AND 4r8_startup document
Hello
having issue trying to use 4r7 and 4r8.
I customized the UI for both. No issue
But when I want to save the current workspace as the default startup document, the save is working but it gives the exact same name (startup document) undependently from the version you are working on.
Is there a way to save a startup document for each version with a specific name and/or folder?
For now, each version just overwrites the previous version…
The consequence is that, if I am on R8 and save as start up document, close zbrush and then open ZBr7, it just simply doesn’t work. I need to press escape then I have my UI for r7 but not my startup document at the good size and background.
Thanks
I think the more pressing question is why do need two different versions of Zbrush running in tandem?
